Rekin, if you had rolled / flared your guards, you would have been fine.
See what you get for running mexican fitment Pat?
haha true
Chucked on the stockies on the car. Reversed the car out of the garage and scraped the freshly resprayed bar pretty badly. Going from the 17's to 16's lowered the front of my car just enough to bottom out :)
After defect cleared, gonna get the guards flared and dial in some camber. Sitting at -0.5deg on the rears. Might go for -1 or -1.5
Although what I have learnt is that you need to leave some crumbs for the cops. Else they will keep searching until they find something really hard to fix like a turbo, injectors, tune or window tint
looks like a S13 for starters.
man this iPad blows baby goats. The user inteface is nice n clean and slick, but the moment you load it up with features in an app or install more than a handful of content rich apps, the shit just slows right the fuck down. its so closed off as well... like... you can't print anything off it. which kinda sucks, that's one of the first things I wanted to do on it. Maybe use it to access photos I took with my camera... its got a great photo management and display app, but no way of getting any decent pics onto it straight off my camera.
fuck this shit. I'm buying an HP Slate when it comes out. That said.... free iPad how can I say no? :thumbsup:
that looks like a mega full cage... 2 cross beams in the back and no back seat.
the widebody kakimoto 33 runs a cage that has 2 loops that go into the rear seat, but it's still useable. Does that help? I can get you pics of that.
www.paulr33.com
unlimited everything quota, space, mailbox, features etc
$5 a month charged on a 2 year contract www.justhost.com
hmm, definitely sounds better than my 60 a year, quotad, limited hosting that drops out quite often... really must swap next renewal time
funky you know your iShit yeah?
sent my iphone off to be repaired/replaced (f**ked it up real good so hopefully replaced), but I wanna know if
A) when I get the new one, if I connect it to my PC and hit restore in iTunes, will it restore all the shit from the last sync/backup of the other iphone, and get back all my messages/apps etc...
and b) if the answer to a is no, is there a way to access any of that stuff through the backup files that itunes would save somewhere when you backup/sync the phone?
Anyone bought a modified car from interstate before?
I'm wondering if it would be hard to get registered.
This is seriously tempting me...
http://www.carsales.com.au/all-cars/privat...MR2&trecs=4
Edited by jezza boii
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
