arent 34 guards bigger then 33?
barely, but that is talking bout gtst vs gtt. r33 gtr guards are bigger than gtt and about on par with r34gtr
yeah gtt guards to 33 gtr guards we are talking bout
they'll look hot, but they won't be flush.
ah fuck it, you'll probably never lower your car to epic stance anyways, so nobody will notice that they're 7mm further in than they should be.
he better be giving away a free reacharound with em at $3700 tho. or at least offer to cup your balls for a solid 5 mins.
haha
that said 19x9.5" +11 > 18x10 +15
more clearance from struts, larger diameter.
If you're not gonna fit them spot on, then at least get the ones that are gonna look nicest. 19" GTC's look way nicer than 18" ones... dunno why, maybe cos they look nicer in larger diameter on 350Z's.
I just re-read your original post, they're both 9.5" wide so you should be fine cos its only the offset that's different. Thought you said 9 and 9.5 for some reason.
ah ok so those 19s from import monster will be completly 100% fine the +11 and +21? cool that means i get a choice ;)
i know that Matts will probably be in better nick thats the only issue but his are expensive
Funky, anything wrong with my fitment? ;)
This is the look ill try and achieve but this is how it looks when im entering my driveway on an angle. So the body has shifted over the wheel.
Should I downgrade to 8inch +30's or try to force fit my 9inch +30's with 255's lol
sick of auto.
if your sick of auto then maybe you should buy my car its not entirely auto, its tiptronic as well, with a shift kit. ;)
so buy it lol, i need it gone to make room for my new and better car.
I'd thought Fujitsubo would sound a lot more quiet..?
fujitsubo make about 4 different types of exhausts, only the Legalis (or Regalis in japlish) is quiet IMHO.
Ah yeah, true that and the quiet ones would be the Oval shape mufflers yeah...
I keep remembering Juliette's exhaust on her R34 GTT and it's pretty much silent.
:blink:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
