"Import Monsters fee – Minimum 2,500yen, then 20% of the purchase price up to a maximum of 25000yen. So even if you bid 500,000yen, the maximum fee you will pay is 25,000yen"
haha well i did have a look at streeters site, found it a bit wtf and only had a hour to like bid and win so just used credit card into importmonster account, and just payed the rest off with my bank account.
25 000 Japanese yen = 286.755285 Australian dollars
i don't mind really as long as i get em :) as for the "~$1k" turns out in total got them for 2800, gave aaron a call today to confirm everything is all good :) now just got to play the waiting game, i will jizz when they arrive.
anyway im off to work!
lol actually, I'm using jesse atm too, cos laurence is down here in melb atm.
jesse's on the ball when it comes to bids and stuffs, I swear the nga never gets off the net. wotanerd :)
Don't do it. Lol
too late, I'm already bidding on it. god knows if 10.5 +5 will fit under the back of an R32 GTR guard. Otherwise it's time to get the sledgehammer out again
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
