"Import Monsters fee – Minimum 2,500yen, then 20% of the purchase price up to a maximum of 25000yen. So even if you bid 500,000yen, the maximum fee you will pay is 25,000yen"
haha well i did have a look at streeters site, found it a bit wtf and only had a hour to like bid and win so just used credit card into importmonster account, and just payed the rest off with my bank account.
25 000 Japanese yen = 286.755285 Australian dollars
i don't mind really as long as i get em :) as for the "~$1k" turns out in total got them for 2800, gave aaron a call today to confirm everything is all good :) now just got to play the waiting game, i will jizz when they arrive.
anyway im off to work!
lol actually, I'm using jesse atm too, cos laurence is down here in melb atm.
jesse's on the ball when it comes to bids and stuffs, I swear the nga never gets off the net. wotanerd :)
Don't do it. Lol
too late, I'm already bidding on it. god knows if 10.5 +5 will fit under the back of an R32 GTR guard. Otherwise it's time to get the sledgehammer out again
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
