man u gota get onto it.. the guy who runs p/c is young hires all hot birds doooooooooooo it i need a way in :happy:
he could be your wingman " hi haaaaave you met alex?" ( love how i met your mother, its a great show)
that's a shame! you should get him back on the bandwagon
my dad is still young at heart - sl55 amg and cbr900 in the garage
I am trying to get my dad back in the game again by getting a 240Z / 260Z.
He's just driving around in a Camry atm...
Ah well, at least it get's him from A to B.
Pics!
Found these pics on uk forum :happy:
That's Dave from GTRShop's old do-luck R33 GTR. Runs 19x10.5 +12 all around.
Yours are +21 offset, which means it'll go into the fenders by 9mm (and also means you have 9mm less clearance with your suspension). You may have to run a small spacer.
dear alex,
fuck off.
kind regards,
shan
Yeah, not bad for a 33 but I'd still prefer a 32 :happy:
please don't weigh in on this when your choice of cars include a poopra, a 300zx and an MR2. :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
