was looking at that yesterday...lose the 34 GTR wing and it'd look a lot better...
I agree. I don't think the wing suits.
Other than that it's a pretty sexy car :ermm: Just a shame that it's out of my price range.
So whos going on the cruize over the black spur? this weekend. I'm considering it
Considering it if I am not doing anything else.
LOL!
+1
lol poor man's R34 NUR.
even got the N1 vent, paintjob and all.
:ermm:
Millennium Jade is only meant for R34 GTR's.
Same with the R34 GTR spoiler, only meant for R34's.
I don't mind millenium jade on the 32. "I'm highly offended" by the fact that the dude's tried to make his 32 exactly like a NUR, by fitting the vent and wing.
R34 Turbo's + Brembo's + Millenium Jade = win
R34 Turbo's + Brembo's + Millenium Jade + N1 vent + 34 GTR wing = try hard Nur = fail
What N1 vent are you talking about?
You mean the 2 in the front bar?
I just noticed the R32 GTR we are talking about has a shaved boot / no key hole.
Junior Wing Suite:
Ah, ok...
Looks nice!
On the bonnet. V-Spec vent? N1 Vent? Whatever model it is that came standard with a NACA duct on the bonnet.
Ah ok I am with you now!
I thought you were refereeing to the R32 GTR jezza posted and all I see is a HKS style vented bonnet.
Yeah I know what you mean.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
