i get plenty of those butttt you've obviously havent found the holy grail...damn forums rules cant post name :ermm:
The brothel? is that the holy grail??
We were thinking about 9pm ish at the lookout or something, I'll text you the details once i sort it out with him
Shan you must have!
Even though it is a GTI not a R32.
yeah look, my golf cost me $2000ish at the auctions and $3000 to fix up.
That one costs about $40,000 at the stealership.
haha what happens in the western suburbs at that time is really gay lol
come tonight billy few ppls heading down
if i understand correctly from what's been written, im assuming a gay orgy is happening tonight.
is this true? and is this why the western suburbs is really gay lol.
yehhh its mass reach arounds... get on it
Any one wanna cruise around the south east tonight? Not in the typical homo western suburbs way so don't bring lube kthx
hmmmmm choices choices, now i do like a good reach around so im leaning towards that one, while the south east meet up says dont bring lube and i dont think i really have the time to stuff around with foreplay, because without any lube everyones going to be very red and sore the next day. so id have to choose the first one.
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
