not as depressing as being in sydney...
I will agree that it's a bit of a shit hole, but the weather was nice and I was staying in a 5 star beachfront apartment with a Mercedes chauffeur to drive me around for 2 days. Free food and alcohol wherever I went.
Now can you see why going back to Melbourne was depressing? :(
I never knew Melbourne didnt have 5 star beachfront apartments and Mercedes chauffeurs
Cause thats the only way I can understand what you said :(
Maybe you should say your current position in your career is depressing not Melbourne ~_~
edit: become a drug dealer and you'll have plenty of mercs and apartments where ever you travel :(
Shhh :( You know what I meant.
And no thanks.. would rather A) earn an honest income and B) not end up in jail or dead :)
