Just making sure you know that CAMS approved half cages are rear half, not front half.
http://www.camsmanual.com.au/pdf/10_gen_re...dule_j_q210.pdf
of course its rear half.. why would i get front half :)
yeh its approved and shisss it seems steep but aint no1 else got them that i can find. this guy wrote the RWC manual on roll cages so he knows his stuff at least, not that i care overally im a defect waiting to happen :P
902 is unfitted to but probaly chuck it in with mates
i do, i get along with most people on here
yeahh i try not to offend anyone on here.. wouldnt be good
although i do hold a grudge against shan for changing my username to ladytron ages ago...
kent :P
For reference, I payed $950 for a half cage, with harness bar fitted in my 180sx from BD. Mind you it was about 2 years ago now though.
Since when aren't bolt in CAMS approved Shan?
I had a half cage bolt in from Brown Davis, and it came complete with CAMS paperwork and never got pulled up with scrutineering.
alr33x:
Their work is awesome, so I highly recommend them, but they need a few lessons in customer service :P
since the 2005 handbook (section J) from memory (I could be wrong haven't looked at it in a couple of years). depends on the event you're competing too, half cage is fine for speed events, but for rally etc you need full cage.
Also just cos its CAMS compliant doesn't mean it is ADR compliant. Guess it all depends on what you want the cage for? street or track?
thanks man
its for drift events and street.. according to BD its fully compliant and street legal but meh.. doubt mr.plod will listen to that anyway was just wonderin about price and if their stuff is decent more so.
to get from japan will be 1k++ easy plus i was told streeter doesnt do cages so then gotta go to importer who will wana make a cut as well :P
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
