I've never been the biggest fan of red. Black is more my style :) A nice shiny black.
Man... I'm getting wood just over that description!!
Hmm... Flared guards... How would that look on mine? I'm going for a similar bodykit to last time but more aggressive rear bar and alternate front.
Get some decent wheels to go with the black.
Silver / Bronze or Black with a Red lip... That's how I like my Black coloured cars
I like chrome lip wheels. Centre can be silver/black/gunmetal, I don't mind.
I want something like TE37s but it's hard finding good offset in an MR2.
7.5 in front and 8.5 rear with +29 offset on both would be exactly flush.
Is this the kind of look you like???
Edited by jezza boii
Fucking love that look!
WORK Meister S1's or SSR Professor S1's, both look great!
On that note, both those wheels look the same. :)
Cuz of the polish lip, you can mix up the colours a bit to get some variety happening.
Any of those center colours would look sic!
The Time Attack TE37's would looks nice, but good luck finding those. Hah!
those wheels will probably cost more than the price of your car :) at least that's what I found with my golf and work meisters.
Yeah, I won't be getting Meisters. I only want to spend about $3000 max on wheels + tires.
So what do you think of the overall look of that car Shan? Coz that's my inspiration for this project.
But unfortunately I won't be pulling 330rwkw like him :( Otherwise I could buy in on this "my dick is bigger than yours" contest between Kris and Hamish :P
grow some
ahahahahah
nah i dont wana mess to much with what mitsubishi already made good
i have seen the 1/4s being wrecked because its flared out, evos in US that have had them done
ill roll the lips though
just pump the whole guard then.... i got nearly 2 inches on my 33 like that :)
(but get athid to do it....)
and no I dont care if kris has more power than me... i actually hope he gets it as he NEEDS it to get away with the paint :(
yeh thats what i mean pumping or flaring its gona look shit on the evo
lipping the 1/4s is all you can really do cause the 1/4s look good as they are
I've never been the biggest fan of red. Black is more my style :( A nice shiny black.
:) okayyy...
haha if it stays too long in one spot it'll cause permanent retinal damage. with 300kw, it'll only be temporary
2x Adjustable Cam gears - $129 from Access Auto
Water pump, timing belt, bearings, seals, fuel filter, thermostat, stud/bolts - from Kudos Motorsports
ASI 52mm dual alumn radiator - $200
Need moar money
Then comes other crap to get water/meth working and then re-tune :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
