yeah, just need to give em time to spin up the metal and drill it up, heat treat it, etc. Apparently 6 week waiting :)
Damn!
Worth the wait I guess...
Shall be all good.
As usual, I expect an epic stance / fitment as that is what you turned me into.
An Offset Moderator :)
Fuck I am picky with Offset and stance thanks to you Shan.
funky is a novice offset nazi.
haha
Your the next Offset nazi!
Hah!
He's a good influence though. I can't believe I used to be content with a $1200 wheel/tyre package from TTF in fail offset!
Shan has changed my life :D
For the good I suppose...
We don't want to see you rolling on shit wheels.
++11111111!!
go back 3 years, i thought pastel paints and f**k off big chromies from bob jane were awesome
i joined the forums, saw hamish's car at the GP and thought. f**k... looks allright
saw the shit funky was posting up and thought my god, this is brilliant.
LMAOOO get a skyline and then try make a comment hahaha
Exhaust scrapping everywhere, Tyres scrapping in the inner wheel arch and guards for flushness and lowness would qualify my car as being low.... Just ask Alex... He's cars a 4wd next to mine lollll
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
