yeah, just need to give em time to spin up the metal and drill it up, heat treat it, etc. Apparently 6 week waiting :)
Damn!
Worth the wait I guess...
Shall be all good.
As usual, I expect an epic stance / fitment as that is what you turned me into.
An Offset Moderator :)
Fuck I am picky with Offset and stance thanks to you Shan.
funky is a novice offset nazi.
haha
Your the next Offset nazi!
Hah!
He's a good influence though. I can't believe I used to be content with a $1200 wheel/tyre package from TTF in fail offset!
Shan has changed my life :D
For the good I suppose...
We don't want to see you rolling on shit wheels.
++11111111!!
go back 3 years, i thought pastel paints and f**k off big chromies from bob jane were awesome
i joined the forums, saw hamish's car at the GP and thought. f**k... looks allright
saw the shit funky was posting up and thought my god, this is brilliant.
LMAOOO get a skyline and then try make a comment hahaha
Exhaust scrapping everywhere, Tyres scrapping in the inner wheel arch and guards for flushness and lowness would qualify my car as being low.... Just ask Alex... He's cars a 4wd next to mine lollll
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
