hear is the list of his mods:
Trust T78-29D 14cm installed for quick spool up on the 2,700 engine, very high response even in town driving.
2,7L specification
HKS 87mm forged piston kit
HKS con rod and crank metals
HKS STEP 2 camshafts (264/272)
HKS sliding cam pulley
HKS strengthening valve spring
HKS Head gasket 1.6mm
Dynamic balanced crankshaft
Head ported and polished
Combustion chamber process (squish area removed)
Block bored to run the HKS 87mm forged pistons
TRUST T78-29D 14cm turbine
TRUST racing External waste gate TYPE-R
TRUST front pipe
Trust exhaust manifold
Essential OIL catch tank
SARD 700CC injectors
SARD FUEL PUMP RELAY
NISMO fuel pumps ×2
SARD fuel pump wiring KIT×2
SARD Fuel pressure regulator
HKS fuel rail
EAARLS fuel line
ARC pre- stage - R
SARD low temperature thermostat
Aluminium radiator cooling panel
GReddy upper radiator pipe
FULL STAGE full titanium Exhaust system (custom made)
HKS superpower flow
APEX ECV
HKS TYPE-R 3 layer intercooler
HKS intercooler piping
ARC twin core aluminium radiator
Drive train/Brakes/Suspension:
ATS Twin plate clutch
AP MINE'S 6 pot brake callipers front
355MM 2 piece brake rotors
BREMBO standard rear brakes
SEIDOYA brake pads
Stainless steel mesh brake lines
NISMO 1.5way LSD
PRO Drive 18 inch Alloys
265/35R18 93W - Bridgestone Potenza RE55S (Semi-Slick)
CUSCO front upper arm
TEIN pillow ball tension rods
QUANTUM coil over suspension
CARROZZERIA CD player
Latter-term type projector HID headlights
Racing gear 6500 Kelvin HID (Hi&Lo)
Optional OIL cooler duct in bumper
N1 front bumper duct
N1 front hood top mall
NISMO side step
NISMO rear bumper
Endless FRP Bonnet
HKS F-CON V gold PRO
Blitz dual SBC boost controller
TRUST turbo timer
Defi link controller
Defi oil pressure gauge
Defi Oil temperature gauge
Defi water Temperature gauge
Defi boost gage
NISMO full scale 320KM meter
NISMO gauges
Roll cage (new)
MOMO competition steering wheel
DU-LUCK rear cross bar
DU-LUCK rear floor bar
BRIDE ZETA-III drivers seat
Can't wait to get home. Gonna polish up my exhaust and give my interior a good clean. Getting new seatbelts tomorrow.
I love being able to work on a car again :ninja: Even if it's just detailing. The Supra has always been way too immaculate to change anything.
It looks like it was just overfill :ninja: I'll have a look under it again when I finish work but I'm 99% sure it's all good :banana:
Goes in for the RWC on Monday so hopefully not too many unknown issues.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
