Flares on Ebay
He hasn't got any up at the moment, but he makes them routinely. Just do some measuring to make sure they fit. They're pretty flexible though, have a set sitting in my cupboard
Your a gun thanks champ! :)
that aint poke that just plain dont fit, bolt on flares are the only answer even camber has its limitations.
foolish child, you underestimate the powah of demon camber.
Wooot! After many hours of work my audio install is complete. Farkkk it is LOUD and clear.
Over $4000RRP of shit in there. I didn't pay that much though obviously ;) Cost price FTW.
so is the amp in the front of the car? is this your lame attempt at gettin more kw under your bonnet than kris?
demon camber is bullshit
you take that back right now.
those flares aren't gonna cover all that poke if you can't camber it. Doesn't lowered spring do anything? Find a cefiro and swap the rear axle out of it.
parents usually leave their car unlocked on the driveway, they noticed on the weekend that the door wasnt closed right. Had a look through the car and noticed that the service manual + all other documents in the pouch (headunit pin number, manual, initial deposit receipt for car etc) were taken...
Nothing else seems to be missing...
What can they do with all this info? Can they get a key/alarm programmed by just flashing this book to any Mazda dealer? Something fishy going on here, cause they would have had to go up to the door to see if it was unlocked and then know to take the service book etc?
Oni Camber is the Demon!
Looks fucking mad!
haha i was borrrrreed. it in the 'my assistant' next to 'view new posts'
Ah ok cool, thanks!
this is probably old and everyone has seen it but for the ones who havn't this is the perfect drift.
Best entry of drift ever!
epic camber on rear = no no, live axel :down:
bolt on flares on the cards :D
the mexican look is fine, my mexican girlfriend can drive my mexican car :P I'm gonna get killed when she reads that rofl :happy::D
I'm not f**king mexican. Either you call me guatemalan or spanish, not mexican. I'll have to think of a way to get back at you! :):P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
