thats a joke really
where abouts was this mech located?
Very very well known place. Well enough that if I named it I'm sure everyone would think I'm blatantly lying...
why'd you send it to SA when knox automatics can do it in VIC?
also exactly what are they havin issues with?
I did initially call Knox autos. They told me they don't touch the R34 Triptronic system in terms of adding a shift kit to it, though they were happy to service one etc, or provide upgrades for 33, 32, but no valve body upgrades for the Triptronic from them.
Hence, MV Autos in SA.
I'm not that savvy, all I am is adept with lurking these forums and /search. I've been told the issues are due to the R34 NA and Turbo being wildly different behind the scenes, they can't actually get the car going well enough to get a reading from the ECU re: Error codes and the car is constantly in limp mode. Even though all the wiring has been changed, I've been told it's due to an issue with the dash, and that it may not be possible at all.
I would have thought that if you change the engine, ecu, and all the wiring between all the components and the transmission with the turbo gear, it should actually work, considering it is infact now a factory turbo car.
But what do I know :laugh:
are you trying to use a factory ECU? just use one that can be programmed to ignore the tacho anti tampering.
Yes.
Unless it's going to pass an EPA (i.e Nistune?) then I don't want it.. otherwise I'd be in this situation one day when someone goes OLOLOLO AFTERMARKET ECUS!!! JOO MUST REPLACE!! (I am sure EPA representatives speak like this)
I did ask if Nistune would work, but was advised that it wouldn't be able fix the issue by just tricking the car into ignoring niggly crap. That said, the shop doesn't do Nistune. So it'd have to be towed somewhere else. That's pretty much what is going to happen if they do throw their hands up in the air and declare it an impossible job.
Then get em to intercept the signal and change it to something the ECU accepts as normal and carry on doing what it does.
Also, no one I know of has had their R34's ECU checked to make sure its standard. OBDII scanner won't work cos its an R34, and a CONSULT scanner won't work cos it's an OBD port on an R34. harden the fuck up and put in an aftermarket ECU. If its as modified as I think it is, then that's gonna be the last of your worries if someone is goin over your car.
arden the f**k up and put in an aftermarket ECU. If its as modified as I think it is, then that's gonna be the last of your worries.
Not trying to argue (especially in such a light hearted wasteland thread) but whats the point of doing that, only to get done, and having to replace the aftermarket ECU with a legal one, placing me squarely in the same situation with additional cost :laugh:
As for the car being modified, it was originally probably f***ed beyond hope of any kind of fix. Infact it was. That's pretty much why I said remove everything in the damn car and replace it with everything factory. I used to have visions of burning the workshop down to claim it on insurance, but now that I cancelled that.. or rather chose not to renew the yearly payment yet.. I'll have to eliminate arson as a means of getting a working skyline, lol.
w00t. work meister S1 outer barrels gettin anodised blue tomorrow :)
still trying to figure out if I wanna polish the centres or get them water transferred with fake carbon pattern or have it powdercoated matte black.
headlights and tails are goin black, so it'll be blue with black details. probably should just powdercoat the centres black n call it a day. I can anodise the nuts black too that way.
Shit's gonna blow these golf kids minds with awesomeness.
fitment... pokes out of guard by 5mm and tucks with stretched tyres. distance from fender to rim... 4mm :laugh:
and now I've got no spare monies. come onnnnn tax return.
Saw fake CF centers on a 180 once...looked aids.
I'd go black, but you might come up with a better CF finish than what I saw..
wow, so it's bog standard? yeesh... the thought of just cuttin your losses and buying a standard car that worked didn't cross your mind?
It wasnt initially, its however (attempted)? to have been transplanted with bog stock everything (i.e, stock ecu, stock RB25det neo, looms from the GTT engine etc), except it all doesn't want to play nice. I was under the impression it would be easy to do so, so I agreed to it. Remember, I'm not mechanically minded at all (f**k, only had the car 2 months in my actual possession since I bought it about a year ago), so when a very well regarded places recommends replacing the entire engine with a stock one, with stock everything else to get it going it sounds drastic but I trusted that judgement. Obviously if I could go back in time, a lot of people would have made some very different decisions. :laugh:
Yeah it was just an idea, I don't like the fake look of it...
Should have bought a R34 GTT...
no pics till they're fitted an on the car, so at least a couple of months :laugh:
I will be waiting! :)
Hi everybody! ... Hi Dr Nick.
I can't wait for friday gonna finally get a power figure to see what I'm working with
You have a 1988 Sillycar?
Yeah see you Friday.
I will be waiting! :laugh:
Yeah man, I call the sillycar the Red Barron, It just pisses oil on everything and clunks around. It's on its last legs. ATM my housemates using it as his doing a re-build on his Gtir.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
