Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :P
$600 in the red FTL
shhh. he's building a track/street car. :D
y'all nga's just lack foresight.
:D
in other news, got caught in that massive downpour before... absolutley soaked :)
least i got the rest of the day off
And you need all this why? Lol
dunno bored i guess
Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :D
$600 in the red FTL
proper shrouded thermo fans > engine fan
shhh. he's building a track/street car. :(
if they are, thats good
was hoping they were std globe and not some uber spec light assembly in one piece
will check it out when i care and can be bothered
dont drive my car to work so not urgent urgent
white ones or yellow ones? or regardless of colour?
All foglights are illegal regardless of colour, pretty lame. Unless they turn on with the headlights then they are legal, but if there is a separate switch then they are classified as foglights
the 32 and the evo both had the foggies in the headlights (both use a switch for them, 32 was the sedan h4 n1 style light)
how does that work then when they came from factory like that but dont turn on when you headlights go on?
I have a button on top of the dash. Near the rear window demister for the foglights
the foglight button would turn on the foggies and the parkers, but i think law means that when you switch to headlights the foglights will then turn on. Some crappy outdated law. I wonder if there is a law for the white LED strips under all the headlights
some confusion between fog and driving lights here
Using fog lights
Front fog lights are designed to better illuminate the road in fog, snowfall, rainstorms or dust clouds. They can be recognised by the narrow pattern of light emitted.
Road Rule 217 states that drivers must not use front or rear fog lights unless driving in fog or other hazardous weather conditions that cause reduced visibility.
Fog lights cannot be accidentally switched on. They must be switched on separate from the main and dipped beam head lights.
Using driving lights
Driving lights are designed to illuminate the road over a long distance. They are the same as the high beam (main beam) head light and emit the same lighting pattern.
Road Rule 218 states that drivers must not use the high-beam headlights when driving:
* less than 200 metres behind a vehicle travelling in the same direction
* less than 200 metres from an oncoming vehicle.
Driving lights cannot be accidentally switched on. They can only be switched on and off with the high beam head lights.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
