Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :P
$600 in the red FTL
shhh. he's building a track/street car. :D
y'all nga's just lack foresight.
:D
in other news, got caught in that massive downpour before... absolutley soaked :)
least i got the rest of the day off
And you need all this why? Lol
dunno bored i guess
Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :D
$600 in the red FTL
proper shrouded thermo fans > engine fan
shhh. he's building a track/street car. :(
if they are, thats good
was hoping they were std globe and not some uber spec light assembly in one piece
will check it out when i care and can be bothered
dont drive my car to work so not urgent urgent
white ones or yellow ones? or regardless of colour?
All foglights are illegal regardless of colour, pretty lame. Unless they turn on with the headlights then they are legal, but if there is a separate switch then they are classified as foglights
the 32 and the evo both had the foggies in the headlights (both use a switch for them, 32 was the sedan h4 n1 style light)
how does that work then when they came from factory like that but dont turn on when you headlights go on?
I have a button on top of the dash. Near the rear window demister for the foglights
the foglight button would turn on the foggies and the parkers, but i think law means that when you switch to headlights the foglights will then turn on. Some crappy outdated law. I wonder if there is a law for the white LED strips under all the headlights
some confusion between fog and driving lights here
Using fog lights
Front fog lights are designed to better illuminate the road in fog, snowfall, rainstorms or dust clouds. They can be recognised by the narrow pattern of light emitted.
Road Rule 217 states that drivers must not use front or rear fog lights unless driving in fog or other hazardous weather conditions that cause reduced visibility.
Fog lights cannot be accidentally switched on. They must be switched on separate from the main and dipped beam head lights.
Using driving lights
Driving lights are designed to illuminate the road over a long distance. They are the same as the high beam (main beam) head light and emit the same lighting pattern.
Road Rule 218 states that drivers must not use the high-beam headlights when driving:
* less than 200 metres behind a vehicle travelling in the same direction
* less than 200 metres from an oncoming vehicle.
Driving lights cannot be accidentally switched on. They can only be switched on and off with the high beam head lights.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
