lol if it's still as emo as it used to be that engine will give up the goose before you even get to the track :D
hopefully it's grown past it's teenage emo stage in life.
lol if it's still as emo as it used to be that engine will give up the goose before you even get to the track :P
haha the engine has been good to me. Its just everything else which has had hiccups.
If engine blows, might look into a rb22 for the lols.
Thermofans is nothing ground breaking. All new cars have thermos, just replacing old technology with new :P
Thermofans is nothing ground breaking. All new cars have thermos, just replacing old technology with new :)
rb25 and be done with it fool
I've been on the job for over 20 years, and I fail to see what fishing bricks from the bottom of a pool has got to do with bank robbery. And on top of that, they got me babysitting some quarterback punk, named Johnny Unitas or something.
Point Break. Good movie
tomorrow playing footy then seeing Get him to the Greek
proper shrouded thermo fans > engine fan
Cant edit previous post;
thermofans ftw :)
SIF
The HP gained by pissing off the clutch fan, is inadvertadly lost via the extra heat the thermo's cannot dissipate.
Cost vs gain - i don't see it.
I run around @ 67-71 degree's reasonable hard driving hard on the street/hill runs with just a Race Radiator item & factory clutch fan - none of this pussy idle business :P
See how you go with 15mins of solid 280rwkw heat and then come show me :)
Dammit, I'm ashamed to be German now :)
On another note... Was having an argument with a Honda fan boy on Facebook.
He said "hydrolock can cause you to blow a piston or a tie rod"
I loled so hard. Tie rod = http://www.autoclinix.com/Mercury/TieRods1.jpg
farken cops are flamin mongrelfaces. fail to give way to pedestrians (me) at an intersection, then gave my mate a fine when he spat his gum out, because he "spat at them for failing to give way". he was doing no such thing. flamin mongrelfaces i tell you
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
