I'll make it back to a (pancake) duck meet one day
You gotta new car yet?
Just picked up my new SSRs :angry: They're kinda farked (gutter rash, little dings) but should be easy enough to repair.
And Thuy says hi Hamish :P
Pics when on car.
When I can sell my f*cking Supra I'll get tyres and put the wheels on the car.
I've dropped my price by $2500 now and still no bites.
That will teach you to buy a N/A Supra.
:P
Good luck selling it, you'd need it.
neways are pretty cheap and well good at repairing gutter rash
That's who Nick suggested. I don't know when I'd find the time or a transport car to get over to their shop though :P
Is there any decent places in Dandenong?
Ajax in moorabbin
But how bad is it? I have rash on mine that I bought for a steal from Thuy, it doesn't bothe me at all...
how did u win that gorgeous thing, pat?
haha entered into an employee competition (i work at cadbury)
Lucky for me, everyone is too busy working to bother with the competition :cool:
Opening it up, its actually 5x 2kg blocks. Which makes sense cause the production line isnt setup to create such a huge block! (cadbury blocks made in tasmania)
You can buy them from here;
http://www.fundraising.com.au/products.asp...t_16_category=4
Ajax in moorabbin
Some scratches are pretty deep and there are some actual dings.
Plus I want every aspect of the car to be looking 100% (hence why I bought all new plastics, lights etc. when I didn't really need to) so yeah, I'll be anal about these wheels too.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
