Now we can start talking wheels and offset sizing!
:D
Atleast you have the car now.
haha well i had it all organised, i only just got the rims last week (took about 2.5 months to get here) so worked out good for me :).
So what mods do i do? or just leave it stock because I already shit bricks when driving it hahaha
haha well i had it all organised, i only just got the rims last week (took about 2.5 months to get here) so worked out good for me :D .
Street use for GTR you'd go turbo back exhaust.
An APex'i Power FC with a tune and if you want up the boost a bit but that will depend on the health of your turbos if they are stock / aftermarket.
Then do the cam gears with a tune, if you want to go that far.
Suspension and wheels will help a lot.
Stock Air intake, Intercooler, BOV and Brembos brakes will do you fine until you want to start pushing over 350+ kW's at the rear wheels.
Even then your stock BOV should be fine.
I dont want a power FC mainly because my brother got done for having one.. cost him a lot of money..
I think he told me once that you can only get it tuned with a R32 GTR ECU
S1 R33 GTR's yes, S2 no.
There is the answer!
Thanks Shan.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
