everything is worse when you don't have your car.
...I want my car back ;)
haha bad
i wonder when my std turbo will die
yours has been going strong especially for a liner turbo
gota love evo's run 20psi+ in standard turbos :)
Damn Rego is a kunt!
$600+ x 2 for me and my insurance x 2 for me!
FFUUCCKK!
why is everyone getting charged $600 for rego?
i only get charged $515
yeah most likely but shit arsed color, silver is the best in them
Fuck, they want $110,000+ for it!
thats complied, $85000 to just buy it
either way still not worth it
wooo bonus :)
scott you must be in same situation?
yep ive never had to pay near $600.
on another note the boot in the gtr is even smaller than my gtt and bolted in the boot on the right hand side is a cd stacker which is pretty cool. other than that i havnt found any other cool things in it yet.
edit: also my car is at pickles auctions so if anyone was looking for some r34 gtt parts check it out. im pretty sure its at the tullamarine pickles auction.
haha bonus for us *hai 5's*
mmmm i think the new season of futurama is out but i cant find it :)
yep its out, i think they have aired 3 episodes so far, i havnt got them yet but the only way is through torrents.
my car still works you ass. Hardly my fault Asians can't fkn drive n feel like crashing into me is it?
LOL!
Shit happens!
Damn you!
Yeah man, get a V-Spec II Nur for that.
I know all about that.
Ah yeah, you feeling the pain!
You full comp on both cars or is one 3rd party?
ive got one little problem, the car can be a real pain in the ass to start i can have the thing ticking for a while before it finally starts up. how did the guys not notice this? i think it might be the battery even though it has a new one installed.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
