everything is worse when you don't have your car.
...I want my car back ;)
haha bad
i wonder when my std turbo will die
yours has been going strong especially for a liner turbo
gota love evo's run 20psi+ in standard turbos :)
Damn Rego is a kunt!
$600+ x 2 for me and my insurance x 2 for me!
FFUUCCKK!
why is everyone getting charged $600 for rego?
i only get charged $515
yeah most likely but shit arsed color, silver is the best in them
Fuck, they want $110,000+ for it!
thats complied, $85000 to just buy it
either way still not worth it
wooo bonus :)
scott you must be in same situation?
yep ive never had to pay near $600.
on another note the boot in the gtr is even smaller than my gtt and bolted in the boot on the right hand side is a cd stacker which is pretty cool. other than that i havnt found any other cool things in it yet.
edit: also my car is at pickles auctions so if anyone was looking for some r34 gtt parts check it out. im pretty sure its at the tullamarine pickles auction.
haha bonus for us *hai 5's*
mmmm i think the new season of futurama is out but i cant find it :)
yep its out, i think they have aired 3 episodes so far, i havnt got them yet but the only way is through torrents.
my car still works you ass. Hardly my fault Asians can't fkn drive n feel like crashing into me is it?
LOL!
Shit happens!
Damn you!
Yeah man, get a V-Spec II Nur for that.
I know all about that.
Ah yeah, you feeling the pain!
You full comp on both cars or is one 3rd party?
ive got one little problem, the car can be a real pain in the ass to start i can have the thing ticking for a while before it finally starts up. how did the guys not notice this? i think it might be the battery even though it has a new one installed.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
