lol yup, its the old one. it was one with light frontend, which we repaired (all legit, inspected etc.) keep in mind NSX's are rear engined and the front is just a luggage compartment.
btw driftline is now solded. some asian dude bought all the spare parts n all the half done cars for the cost of a couple of R33 GTRs :down:
Fark.. I've gotta buy a guitar amp too. It's easy to spend $10,000 - $20,000 on a guitar rig. I wish I had that kind of coin...
Fuck man, what setup are you buying?
I bought a quadbox and a head for like $750 all together.
f**k man, what setup are you buying?
I didn't say I was going to buy anything worth that price :) I just meant it's easy to spend that much on 2 guitars and amp rig. I've got a mate with an $11,000 guitar :D
At this stage I'm just going to buy a cheap amp for gigs (~$1000) and borrow my singer's Strat or Tele.
Luckily I can use them on recordings too ;) One day I'll buy my own decent guitars. At this stage I just can't justify it.
Woo! got my skyline hoodie. I still reckon the design shits all over the Sau one
me too.... XXXL ftw
And can't he broken with ruff sex
depends on how hard you squeeze your asshole phagsiu
If only condoms were made of carbon fiber then :D
get charles to wrap one for you
Hmmm my shocks r getting worse. Coilover time ;)
bout fucking time
what are you gonna do to make it squat for superior acceleration? :)
nice
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
