both, when dennis and charlie dress up gothic like
and then when charlie makes the musical and they all sing in it lol
im up to date for all eps except for season 5
awesome, wasnt sure if you had see the one where he makes that musical called the nightman cometh lol. i love that episode, especially how it sounds like its got to do with rape. " to get into the boys soul you got to pay the troll toll" and when he says soul it sounds like he says hole.
West meet for night cruise = fail.
Finish work at 8 so no chance of making meet point anyways... not that i really want to go to the scum suburbs haha
nothin wrong with the west champ.
you easties forget about all the sh*tholes over that side no worse than what we got out here..
plus our cops are wayyy better.
flawless victory.
Hey can one of you guys with a r33 with a stock rear bar post me pictures of the rear please. Idealy of the section where the bar sits against the rear lights and the skyline panel. Want to known if they is any gaps between them. Need these before the morning if someone is kind enough in a decent quality ;)
Cheers
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
