sooo.. how powerful would one of these be with a 350Z TT setup
I think APS made the 350Z run 12's.
the silver 180 low as fk and certified gangster?
Yeah that's the 1!
probably a panhard flat twin
I see, thanks!
Ppfftt shan. You will only get a little respect when you actually have a car with hellashit fitment.
If you mod your car to get respect from others you should work on your self esteem :/ sorry but you just sounded really silly saying that
you're the one who implied that we mod our cars for the respect of others retard.
because it's a DB HBR5, not a Fairlady Z as the filename suggests
Yeah, I was just doing a little reading and it saying it is a 2 cylinder sub type "Boxer" engine.
Seems to be more of a motorcycle engine.
Cool!
Thanks again.
yeah, looks awesome
also a black one at the electricity joint up mahoneys road, red p plater, primered patches all over the car, flared guards and some sweet sweet fitting dteks
cracked a stiff while limping to work
lol that's ghetto... lotsa maccas wage rolla boys do it and think it's the shit.
but if you are gonna do it, at least turn it the other way around and bolt it to your bumper.
failing that just get a ghetto spec 180SX bumper lip, turn upside down and fit to R32/33 bumper.
its 'L' shaped. will be bolted.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
