I mince my own meat and make my own patties. best. shit. ever.
Huge difference between mince from butchers and a cut of meat that you mince freshly.
I breed my own cows, that I mince my own meat to make my own patties.
Hey guys. I'm currently over from Adelaide, and getting a bit bored. Was just wondering if you guys have meet ups or something?
oh, and your traffic sucks :P
But we have the Formula 1! :laugh::wub:
oh, and your traffic sucks :laugh:
see my sig mate.
well i grow my own feed that i feed the cows that breed then mince to make my own patties
lol wut
I was trying to find that car a while back, it has a twin turbo 351 in it, crazy car..all started cause he was sick of getting a ribbing from his mates about driving an excel..
All i could find was a 4 sale add he wanted 40,000$ for it...
So where,d you score the time machine
,found this trippy thing , can be seen thru the rear window...
http://www.toysauto.co.uk/product_info.php...me=strut-braces
Dunno what gtr is like, i got a cusco one is bent more than that jjr thing is...Does jjr fit behind the backboard...
wow that one looks much better!
yeah jjr one is behind the backboard and thats why i have been wondering, due to most ive seen have been cut through the backboard and are visable from the boot! >,<
how on earth do you change r33 parker globe
does the whole headlight assy have to come out to change it
nah, you can do it with them still in... I have done it a couple of times now.
On the left I had to remove the pod and box (obviously)
and on the right I had to remove the washer bottle
An like dezz i k ow the pain of dropping a globe in there...
DO NOT DO THIS!!!
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
