I mince my own meat and make my own patties. best. shit. ever.
Huge difference between mince from butchers and a cut of meat that you mince freshly.
I breed my own cows, that I mince my own meat to make my own patties.
Hey guys. I'm currently over from Adelaide, and getting a bit bored. Was just wondering if you guys have meet ups or something?
oh, and your traffic sucks :P
But we have the Formula 1! :laugh::wub:
oh, and your traffic sucks :laugh:
see my sig mate.
well i grow my own feed that i feed the cows that breed then mince to make my own patties
lol wut
I was trying to find that car a while back, it has a twin turbo 351 in it, crazy car..all started cause he was sick of getting a ribbing from his mates about driving an excel..
All i could find was a 4 sale add he wanted 40,000$ for it...
So where,d you score the time machine
,found this trippy thing , can be seen thru the rear window...
http://www.toysauto.co.uk/product_info.php...me=strut-braces
Dunno what gtr is like, i got a cusco one is bent more than that jjr thing is...Does jjr fit behind the backboard...
wow that one looks much better!
yeah jjr one is behind the backboard and thats why i have been wondering, due to most ive seen have been cut through the backboard and are visable from the boot! >,<
how on earth do you change r33 parker globe
does the whole headlight assy have to come out to change it
nah, you can do it with them still in... I have done it a couple of times now.
On the left I had to remove the pod and box (obviously)
and on the right I had to remove the washer bottle
An like dezz i k ow the pain of dropping a globe in there...
DO NOT DO THIS!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
