sorry mate you are right, from one end of the exhaust i can fit my hand in but when i try to go through the muffler i can almost get my hand in.
ah yeah thought they were like that, not that it really matters they still flow a lot and the main thing is they keep the noise down :laugh:
^ lol
i got a question for people that know about fitment with rims and stuff. first to clarify im not buying these im just interested in this offset because i dont undertsand what it would look like. ive never seen a number that low usually around +13 offset and stuff like that is what ive seen so im just curious.
http://cgi.ebay.com.au/Lenso-PROJECT-D1R-D...rts_Accessories
18mm more inner clearance (between rim and strut)
and extends out another 44mm
fucken power went out last night, froze while i slept :(
pics phag stop keepin me hanging its like trying to stream a p0rno on dialup..
yeah 4.3 is more normal, no one would sell aftermarket 3.4 diff gears, it would be horrible
so yeah with 4.3 you will get quicker acceleration and lower top end speed
and at 100km./h youll rev more, but your traction will be more important
as it will likely induce more wheel spin as the rotation speed is higher for lower gears
so when you come on power it will likely wheelspin even more if you dont have good suspension/tyres/rear setup
If they dont do the work they shouldnt have taken the diff. It was second hand but there was nothing wrong with it. When the guy opened it today he saw straight away that shit wasnt right. Might be a good thing, im over the 2 ways now, want a 1.5 way.
the point is that it is sent to a specialist who know what they are doing... it's what most tuners do as it gets the customer the best product and doesn't hold up the workshop
yeah creatd don't bust apart diffs.
also how do you assemble a diff wrong if you give em a housing and an assembled 2 way? There's only one way you can assemble it, everything either fits or it doesn't.
i'd say it was f**ked when he bought it and kinda worked when it had fresh fluid in it...
not too upsetting considering what you paid for it kris :(
fucken power went out last night, froze while i slept :laugh:
weird... i was warm?
the lenso's are -1 not +1..
hottt
noooooooooo
wow didnt know auto 33 had higher diff gears than manual
so it runs less boost but higher diff gears
fair nuff
never had a boost gauge in my car, but what should the stock one read at in a manual, assuming standard dump/cat and no other mods?
if it's a bog stock ECR33 auto then boost is 5psi switched to 7psi at 4500rpm
if its a bog stock ECR33 manual then boost is 7psi swithced to 9psi at 4500rpm
for 100km/h in ECR33 manual it is 2650rpm
for 100km/h in ECR33 auto it would be around 2850rpm ish ?
hottt
took that into consideration when i worked it out :)
haha i got a shitty phone pic, cars is dirty as though :huh:
although you dont notice it much being yellow
fark you, power only came on at like 4.30 in the morning so shitty night :)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
