don't BC's come with 7kg and 4kg springs standard? From memory that's around the same rebound rate as stock. Performance gain? Turn the dampening off full firm and see how the bounce rate is. The midrange of most cheap coils are terrible, they only work properly at either extreme due to the nature of their valving. Add to this that BC's don't have progressive springs, and it's pretty much a recipe for fail.
With the same amount of money you could get a very good set of matched springs and struts that will last longer, perform consistently and much more smoothly. Fuck adjustable dampening and height, the only guys who do that usually have $5000 suspensions and visit a suspension shop before and after each event. If someone's on a $1200 budget for suspension their broke ass isn't gonna see a suspension shop after it's been set. ever. they'll just ghetto it up at home every time they get defected.
in which case you'd rag on him for not dragging his balls low enough on the ground (or whatever analogy it is you like to use)
so what's a kid to do?
save up and buy decent coils so he can do both?
not that he'd ever drag his balls too low to the ground, he'd destroy that fibreglass kit of his at the sight of a bump in the road... so he'll be running it at a safe and possibly legal height, so why bother with cheap coilovers?
All i know is my BCs feel good :) and heard good things from suspension specialists, and the reason why my car isn't balls slammed to the floor is becuase of:
1. The area I live in.
2. My dad spent a fair bit of time repairing my front lip while I was doing other things, and would hate to screw up his hard work of repairing it properly
BC coilovers are actually pretty good shan, they are pretty much rebadged greddy's. Spring rates 8 / 4
pigs arse, we've fitted about 3 sets on cars, and they were almost identical to the other equivalent stuff from race logic and G4/D2. Just powdercoated a different colour. Shit we even showed the race logic guy who looked after our trade account and he was like "ummm yeahhhh funny that".
8/4? you had better spring rates when you were rockin superior stock suspension for acceleration.
running 10/8 on the GTS4 on matched Tanabe springs and shocks. Is nice. Bumpy, but not as bad as my old 12/10 setup which was bumpy as fuck, but it's not a daily so I don't really give a toss... and if the passengers don't like it... they can GTFO and walk.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
