pigs arse, we've fitted about 3 sets on cars, and they were almost identical to the other equivalent stuff from race logic and G4/D2. Just powdercoated a different colour. Shit we even showed the race logic guy who looked after our trade account and he was like "ummm yeahhhh funny that".
8/4? you had better spring rates when you were rockin superior stock suspension for acceleration.
shan is right. BC is another version of G4 Racing coilovers and D2. same parts used just different label.
why is it so hard to get r34 gtr suspension parts? first of all ive got all these suspension places online saying these caster rods fit r34 gtr and they dont its a way different shape in the r34 gtr's its driving me nuts so now im seeing if i can buy just the bushes. also i cant find any tie rods and tie rod ends either.
on another note ive got some caster rods that will fit r32 and r33 gtr NOT R34 GTR! im selling them for $150
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
