you nga's need cars that can break traction in any weather.
Auto is a bit harder I guess.
auto doesnt stop me. its just fun, and easier on the car in the wet
At Crown?
Been there a fair few times. Pretty nice food. You must get the Belgian chocolate desert thingo though. Trust me on this.
+1. this man knows
:down:
took your advice and got me a blitz spec R boost controller btw.. gonna be fun hiding that monster solenoid!
Mine was virtually invisible...Too me a fair bit of effort to see it with a torch and I knew exactly where it was..
anyone know where i can get these songs
DJ Antoine - Underneath (Radio Mix)
M'Black - Heartbreak (M'Black Radio Edit)
happy to buy them
itunes US has them but i cant buy it with my AUS based master card
+1. this man knows
+1 but mines manual now.
didnt stop you leaving kings did it basti that one time.. where um LOL / \/.\ || ... / smoethin like that
:D
you cheating whore, you told me your were getting the gizzmo lol :(
At Crown?
nah in port melbourne, its next to the water, always see ads for it on tv?
..... doesnt matter got booked anyway :P
mmmm just saw a pre-showing of the sorcerer's apprentice....... shit, not even worth the fuel to drive there.... let alone the free tickets
good to know it CAN be done... i've got a couple of ideas... won't discuss them here obviously!
you cheating whore, you told me your were getting the gizzmo lol :D
picked it up for just a tiny bit more than the gizzmo. and it's heaps JDM y0.
sorry brah
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
