My friend just had someone run into the back of her car and needs some Subaru parts. Anyone know any Subaru wreckers? I need some names ASAP!
It's a 2004 Impreza RS.
Edited by jezza boii
I just read that wikipedia entry...
an AWD IS250 with a 2JZGTE swap would be kinda cool.... hell even just straight RWD with the swap would be cool. Not feelin the regular versions... you could buy a V36 for half the price and get pretty much the exact same car.
usa gets awd is350 which is turbo (i think)? something special about it other than AWD
don't think so. not many turbo cars in the US pass their smog test. but they make a 3.5l and 2.5l in AWD in japan.
I'm guessing it'll be like the V35 GT-8, which is fuckin awesome for the first 5 mins of owning one, then you start feeling hardgay cos you have a CVT and a heavy car... so you get up to 100k/h and flick down through all 8 virtual gears to pleasure yourself by pretending you're a shit hot F1 race driver coming into a hairpin, but then cry yourself to sleep, cos that's all your car does well.
nga please. no spacers. i was thinkin of those fender flares though.
need to find a set. saves me having to roll my fenders out.
dunno if that fender flared look will suit the R32 bodykit I'm putting on either.
I'm 99% convinced to go clean and shave the rear etc with an R32 bumper and a Ford FG falcon skidplate mod.
Actually make that 100% convinced cos I already paid for an R32 bodykit.
Hmm sent a letter to EPA asking for warning/extension as I was overseas for business for a month... It's been 4 weeks since letter sent and haven't heard anything. Not sure if I can drive the car or not :P useless hippies. Will call them I guess
Sooo...
Got flashed by a speed camera for the first time in around 7 years, so is it easy to get a "official warning"? I was around 15km/h over the limit. I swear they have changed the speed limit on Fitzroy St from 60 to 40 recently.
Sooo...
Piss easy. Admit fault, say you weren't aware of changed speed but is not an excuse as I should be aware of speed limit at all times. You wish to appeal for a formal warning as it is your first offense in over 7 years and wasn't intentional.
Sign, send and wait for response. Done
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
