i just got the rego... pretty clever...
for those that didn't...
this:
is an AIM 9 sidewinder missile
lol
-celsior and +golf and you have what I'm doing >_<
where would 18x9.5+25 sit on a celsior shan?
i was thinking about 5 out on the front and 5 in on the back from wha i have seen
so mebbe 15mm bolt on fr and 20mm bolt on rear
i saw something weird this morning...there was a car accident on the freeway...two cars...one blue and one silver...they both were smashed...but when drove around it, i saw a RED bumper sitting near the scene...lol...could it be a hit and run? or the accident was cuased due to a bumper falling off another car...what you guys think? it really confused me..
3way and the red car was already towed?
hit and run?
bumper fell off another car?
red bumper was in the rear cargo hold of a dc10 and the cargo door blew out (as was the style at the time) leaving the bumper to fall to earth?
red bumper thrown off overpass?
there was no red bumper?
red bumper was infact not in the book depository, but on the grassy knoll?
that gopher from caddyshack did it?
you are colourblind?
it was eps.
hit and run?
it was eps.
what the fark?
nah... place will be bone dry as usual
the targa tasmania boys have a buller event scheduled for the week after so i think we'll be right wink.gif
but how did you see it when it's after yours? >_<
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
