nawww he just got the googlin skills if he had the hook ups
plus she's in the US. I just asked the guy who works on her car for moar pics. he gave me pics of wheels instead of pics of her. fail.
HAHAHA!!! you got good enough skills though...lol...better than what i would...cant find info i am looking for ever...takes me ages...lol..
Where would one take another to go on a 'hip date' now days?
It's been a while, but yeh getting back into it.. the ol' ball n chain..
depends on what your intentions are and what kind of girl she is really. Also, no one says "hip dates" any more. when was the last time you tried to impress a girl? the 70's?
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :O
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Sounds like a good idea actually, maybe save it for a more warm night
take her where you like to hang out usually:
1) it'll make you more comfortable, being in a familiar place
2) it'll give her a good impression of what kind of person you really are
3) if you're a regular, you can pretend to be popular
if you hang out in your mum's basement on the regular, then you're shit outta luck.
I guess that makes sense, These tips can be passed down to virgin-boy as well :P (oh his username is changed again :laugh:)
Maybe when he buys his 32 GTST he will get some action :huh::O
jk.. jk..
Will mount buller have any snow when the cruise goes up?
none in sight last time. i remember driving up there in nothing but shorts during some stages.
HAX!
lolnoob
applying for a job as a train driver... yes you heard right... and they do random piss testing during the application process
good moneys in that man. my cuz (full lebspec - 20's on his gtt. half german/lankan so looks it too) started out driving a few years back and now is one of three dudes that operate the main controls on sydney's entire rail network. he showed me his work - looks like the control room from pelham 123 (denzel/travolta mov) but only 3 dudes allowed in.
i'd give her some poke, roll her lips and then slam her. then flushhhhhhh. car is good too
you sir, fail at modifying cars, pleasuring womens, and euphemisms. all of it. you're doin it wrong.
jk.. jk..
i found that getting a friend to hold them down works well.
dididoitright?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
