thought id do this modifying thing properly and instead of just getting power i decided to make my suspension better, i just bought a bunch of nolathane bushes, nearly there whole catalogue for the gtr. cant wait to see what it feels like when its all fitted :)
lol slow at replying
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Yeah date win
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :)
Sounds like a good idea actually, maybe save it for a more warm night
nah no need for a warm night.... i always get ice-cream with missus down lygon the gas heaters they have along there keep you warm while you eat
This is true :)
Hurt much?
A little bit.. 1st session for the outline took 2 hours which hurt a fair bit especially on my ribs then the other 3 sessions were only an hour. Last session was the top part which I thought was gonna hurt like hell again but I couldn't feel it.. I was more relaxed I think cause I knew it was gonna be finished :laugh:
shan how would 17x9x+20 go on an R32 taxi?
thankss, lots of love, xoxo.
(change my name back kunt :) )
lol that would need some serious flaring and camber to get right. Will be scrub central on the front.
17x9 +30 is the ideal setup for r32 gtst's.
thats what nisskid recomended with stock guards and low.. any chance sedans are different?
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
