best cheapest place to get XD9's?
thinking of going 17x9.5+17 f and 18x10+18 r in matte black on the 33 and throwing the professors on the celsior
(the celsior that i am "mohsen'ing" about)
love it ahahaha
Was told it's ideal to have flexi pipe so the front pipe won't cause welds to crack.
Also, how do I get rid of the white writing thing on windows? Left the number since DECA and I'd like to remove it...
Citrus cleaner. Just don't get it on your paintwork.
Twist sam's/mickey's arm? Was there today.. love that place haha
Grant... Any abrasive, glass cleaner, metho, citrus shit or even elbow grease will do it :banana:
Ta, will give it a shot.
May have one of these around in the house, will give it a go, thanks.
My best mate got sunburnt... in Scotland. Reckon you can top that?
How do you get sunburnt in Scotland? A solarium?
Streeter, but expect to wait a while. Otherwise local, nobody, they are all expensive.
Hmmm interesting you going staggered? I was getting paid out a while ago when I ordered my wheels staggered. Do it! Will look good
JDM concept have them for 2100 in black, so I might end up going there as streeter can't get black ones.
That will end up slightly cheaper than jesse's price when I factor in painting them...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
