Lol leigh starcraft is better than your favourite nerd game, WOW LOL :(
Pretty sure wow is more popular.. and i only just started playing again yesterday :( even then I only play when I'm bored and cant go out dont raid 24/7 like most people..
Go download more porn mate and get capped :D
did you have your cap sideways and flat? and then hold your hand up and sideways in an E shape?
i dont wear caps
do you even have a license to drive?
no, had my l's up and my mum in the passenger seat. its all the rage these days
It was the cheapest GenIII MR2 I could find. So yeah I'm trying to save money where I can. I just want the kit on and the rust removed. It's not really a hard job. DT's did a great job on my old MR2. I seriously couldn't fault it.
It doesn't need to be perfect. It's had a SHIT respray already. Like overspray in the wheel wells and stuff haha
Vu did a great job on athid's car, (athid does vu's more difficult flaring jobs, so they is pretty tight) so it is possible to get a good job from there, but ya gots ta be connected yo :(
car is all back to stock :( Feels weird, am still used to the old power curve haha
retuned to handle the injectors but need to replace the board with an eprom chip now..
Shan, any chance you got a PIC programmer? If i give you a chip and a .bin file, would you be able to load it on?
Gonna do the trackday with all stock parts on the 16th, then put them back on for next track day. It will be like playing GT5 but in real life! haha
looks like a strange mashup between an audemars piguet royal oak survivor
and a hublot big bang
with a quartz movement lol.
don't wear that watch around people who may own either of those originals.
yeah I'm just sayin the meister ambassador seems very "borrowed" from the two originals I posted before.
They're the Rotas of the watch world. Very slightly original yet very similar to an exxy brand, but just as functional :laugh:
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
