Man thats lame as :laugh: sorry to hear it. Yeah it annoys me when people talegate or when your stopped at the lights and watch the car coming up behind you with the driver clearly not paying attention
I hate that as well.
This was just before that accident in Elsternwick where that 20yo got killed when crossing the road.
slowed down with the other traffic then suddenly BANG! i just rolled my eyes swearing my guts out.
pulled over got out of the car and had a look. it looked like there was bearly any damage at all until you look underneath it.
The reinforcement has been pushed up and it was all stopped by the spear wheel. if it hadnt been in there the damage would of been a lot worst.
so now i have to wait for his insurance to call me up before i can do anything else.
and it gets even better since the GTR was my daily. Just venting but i do feel better now.
Oh no shit, I read about that person getting killed this morning :laugh: - I use my gtr as my daily at the moment while im getting a corona on the road. Hearing stuff like how u got hit makes me want to get it on the road even faster.
Thats really unfortunate. Sorry to hear
Hamish, nice watch.
I have TAFE assessment task in 3 part which is due tomorrow but I cbf and don't have the motivation to do it seeing this course will take me to path to nowhere...
Oh, and good afternoon everyone!
I guess its time to get my sisters GTiR running again since she has lost her licence and begin driving that around till the gtr is fixed.
i really should get a another car as a daily but i love driving the gtr plus dont have the money for it at the moment.
i guess Sh#t happens so what you gonna do?
GTR daily ftw, a bit of a head turner which can sometimes be annoying traveling to work pissed off / zombie mode lol.
Sorry to hear about your car dude, Mick will sexy it up again.
Hamish - Sweet watch dude, doesn't your car have meisters as well? :laugh:
do it yourself?
Tried several times to no avail.
I had it jailbroken by a shop in Franga but don't live there anymore...
What happened was, I updated the firmware and lost the jailbreak app - EPIC FAIL!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
