make sure you upgrade your pivot bolt, fork and the right size throwout if you're getting heavier button clutches.
chucked my OS Giken triple in and after one track day couldn't put it in gear. turned out the factory fork and pivot had warped/snapped. another guy who came to the workshop used the factory throwout and fucked his clutch up after one track day.
haha costed me $220 all up with rims
his sending them to a depot in LA where ive got a mate that brings in his stuff from there
and my mate not charging me to ship it here :down:
Sweeeet - have you figured out how wide your flares need to be?
nah not yet, unsure on the exact offset of them yet.... would be massive neg thats for sure lol
once they get it ill test them up on car and measure it all up and go from there
reckon itll beed about 3inch flares though, cause i think the rims are about 8"
tl;dr
summary?
Integra driver failing to understand that venting hot air out of the engine bay is beneficial.
I have another screen shot at home of him telling people that getting water in your pod filter will cause you to blow a tie rod.
Brings the lolz.
who can weld stuff for me? small job, need to chop off a bit of exhaust and weld on a flange and a bit of straight pipe.
anyone? plzzzzz, wanna have car ready for Buller cruise
mmm i can weld, but wether i cbf lol
cefiiiiiiiiilo! with S14A front conversion. and R33 GTR style front bumper. think it's in thailand or malaysia.
Fuck, you know everything!
LOL!
It was in the Internet Movie Cars Database (IMCDB) listed as unknown and no one can tell what it is...
I dunno if i can trust 'you people' haha..
Do you have the equipment? I pay cash ;)
'you people' mayteeee comon..... dont be lyk dis, you knw we gud at wat we do brutha
you pay kesh? thats all dat matters mayteeeee
yeah dunno how much mig gas i got should be fine though.... aslong as the pipes arnt stainless i can do it, dont have a tig
oh if it's in a movie, then it'll be malaysia for sure. they made a couple of drift movies in F&F style. one of the baddies drive a cefiro with some work done to it.
actually. hold that thought. A pillar gauges on the left. must be LHD, which means it's in the phillipines.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
