also.... you can use one of those star type allen keys and smash it into the bolt with a hammer and then turn that...
(that's what holds my steering wheel on these days after i rounded the bolts)
torx head. will try that.
i've gotten 8/24 bolts off with wd40 overnight, the rest arent budging - some rounded by the last f**k who tried this, two by me, and the ok ones just sit still while the allen key flexes almost 45deg.
just custom ordered my new rims from work japan :(
XD9's in matte black 17x9.5+17 f and 18x10+18 r
will take 8-10 weeks
tyre sies? thinkin 225/45/17 and 245/40/18 or 235/45/17 and 255/40/18
oh if it's in a movie, then it'll be malaysia for sure. they made a couple of drift movies in F&F style. one of the baddies drive a cefiro with some work done to it.
actually. hold that thought. A pillar gauges on the left. must be LHD, which means it's in the phillipines.
Nice, but I still prefer your SSR :).
Have you always been running a staggered set of wheels?
nope... but to get the offset's i wanted i had to go 17/18...
had the professors for 3 years now... time for a change :(
edit: i am also selling the rolla for a celsior, and the professors will either go on that, or get sold for meisters that fit better
had the professors for 3 years now... time for a change :)
Man, did you ever track the Rolla, which is what you intended to do :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
