hey... i'm an avid defender of VB... most people that say it's shit are comparing it to a larger and not understanding that it is actually a pretty decent bitter
i also drink a load of carlton
VB is the worst beer ever and carlton draught is only good on tap.
ill drink any other beer its all good. also i love scotch, whisky and bourbon. my favourite is johnnie walker blue label i like to crack that one out now and again :P
in other news i just bought 2 r34 gtr's, the only difference is these ones are a bit smaller and are made by hotwheels :down:
i still stand by my post id have carlton draught anyday over a VB :down:
If you after an awesome beer try Zywiec. Polish beer, will only find in specialty shops of the bottle-o on Brady road, Dandenong :)
Every Polak will swear by its awesomeness taste.
A good German beer is Hasseröder. A lot of German towns have their own local brewery. This is the beer of Wernigerode. Really nice beer!
I'll bring it to SAU cruise!
True Corona is the girl spec beer,
On another note - Asahi on tap is amazing, get it on my lunch break at work with a parma and pot @ Old England in Heidelberg
ill bring a bottle of ouzo to a cruise is the old man brings back a bottle for me.
looks like next meet is gona be a drunken one lol
is your moms gonna be shotgunning so you can drive on the cruise?
the mrs and i drink usually
~2 slabs a week (usually 1 corona and 1 hieneken imports)
a different beer from work as my knockoff 5/7 nights
a case of wine every 2 weeks
a bottle of belvedere a fortnight
bottle of cognag/armagnac a month (mrs don't touch this)
so i get plenty of "variety" :(
Oh deary, talk about a gap. I'd be lucky to average half a Cruiser a fortnight :) Alcohol and me just aren't great friends.
German beer is win. Especially the 500ml standard size, was hard swapping back to regular 300ml size :(
500mL Oettingers - cheap but soooo good :(
I f*kn hate Stella, tastes like beer mixed with goon for me lol.
I got a free 6 pack off a mate, was like geee thankssss.. :) still havnt drunken it
Agree, stella is pretty gross.
My favourties:
*Little Creatures Pale Ale
*Hoegaarden
*Peroni
*Pure Blonde
*Free
lol, almost three pages on alcohol...
I drink barely at all, but when I do it's Vodka Lemon Lime and Bitters going out, Hennessy XO for the reason to drink and not get drunk and Corona/Kirin for sunny days.
I drink that too as well as Malibu and Coke / Vodka Raspberry / Jager Bombs / Aqua Bombs / Tequila Sunrise / Tequila Shots / Vodka and Coke / Cider...
Any of you had a Suicide Bomb? (A reverse Jager Bomb)
125 mL Jagermeister
1 shot Red Bull
A few of thoes = Fucked!
lol Jamie... what don't you drink?? I dont't do the Jager bombs... I do have Belfast Car Bombs though; drop a shot of Baileys and Kahlua/Irish Whiskey dropped into half a pint of Guinness... Yum!
That drink sounds interesting... I am always up for different drinks as everytime I went out it was Bourbon and Coke most of the time, need a change.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
