supra's can be awesome
makin em look good is tricky
and they are fkn expensive which is mega fail
THEY ARE UGLY....THATS IT!!!
hate them...cant stand them...i rather a gtst than a twin tubro supra...thats how much i hate them..
Hope i didnt offend anyone but dun know what to like about them..i struggle to see anything about them..hehehe..
I owned one. Made for a very reliable and comfortable daily. I liked the rear but not the front. They don't really have a lot going for them. People pull some huuuuge figures in them though.
Pretty sure I pulled up at the lights next to you in it one day VSPECT.
HAHAHA!!! ;) if you do, dont mind me snobbing you off... :P ..i tend to do that to supras....i appreciate cars of all sorts but for some reason this is something i find hard to appreciate.... :P
hatin on joo
trust a black man to snitch on a brother.
wait... you're family too! that's it. so off my christmas list.
boo hoo.
is this a secret quest for attention? like posting broad minded personty pics on myspace?
i've got far more effective means of gettin plebs attention on SAU :P
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
