Love bbs lm's.
Looking to get some as soon as i get the money for them.
saw a midnight purple 33 the other day with bbs on it, it had the gold center with the chrome lip looked awesome.
Love bbs lm's.
I almost trade my white GTR for one few months back, but wasn't prepared to cough up few thou on top.
I have since regretted not going for it now...
personally i would rather the white over the midnight purple.
Would of bought a white gtr over my black one but they always wanted an arm and a leg for them.
^^^ Exactly.
I'd take Midnight Purple over white anyday, but it wasn't the case when I bought mine, should have be patient.
Worse thing was I gave up Midnight Purple 40th anniversary GTST for white GTR...
I would of given up the GTST for the GTR as well. I'm not a very patient person.
I think why white is so common is because it is the official racing color of japan so anyone that would of bought a GTR would have been like I want a white one.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
