Cuz your R33 is causing you headaches Haha!
R34 GTR would be sweet, we all know that.
So do it ;)
So true!
Might sell it aggressively after DECA (3 weekends away).
Man, you don't fuck around that's for sure ;)
But I guess, the easy accessibility you have to high performance imports, you'd see so many of them, you get use to the high turn over...
S30 is like my childhood dream car. I came close with a corvette stingray, but I'm determined to have one in my life... which means any run of the mill GTR will get the flick in preference.
I plan on spending a bit on it too. tubs, S15 dash conversion etc, cos it's a bit ragged on the inside and can do with some paint.
I need to start sellin cars too... which means I need to fix some of em... Who's a good workshop in the SE that can diagnose R32 ABS problems? I think I've got a blockage in my brake line, but cbf pullin it all out and checking.
Yeah for sure!
Well I'd take it to my mechanic but they are in Templestowe.
In the SE, I'd say Race Pace / RE Customs.
this was much easier when driftline was around, just drop it off and pick it up, buy lunch, beers or stippers as payment.
might ring up monty and see how he's goin at chasers n if he can get one of em to look at it for me.
femno heyyyy... hmm might facebook him
whats a decent targa top car other than the usual 300zx mr2 etc?
Aerotop Supra (especially TT version) wouldn't be bad.
Pontiac Trans Am (if you're into American muscle)
Ferrari F355 (if you've got deep pockets)
NX, Exa, CRX etc. are all shit.
That's about all I can think of. Other than the Ferrari, I think an MR2 would probably be the best out of that bunch ;)
A 2000 spec 300ZX would be sick, but they're rare as.
I agree that there should be a bigger market. I love targa tops. I reckon RX7s and RX8s would've looked wicked with one. Same with S14/15s.
better remove it from your cars list then, Mohsen ;)
lmao
fixed the r32 ;)
also, spotted an R32 GTR at Creatd. same colour as my car. its so light compared to gun grey!
Edited by Mohsen
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
