apparently 300zx headlights are interchangeable with the ones on the lambo diablos :) they're nice cool cars would be an awesome cruiser for summer. any idea what the 98+ ones go for? and how often they come up at auctions?
looks like someone out there is copying your style because it definately looked like yours.
gone are the days when mine was the only red r34 in the hood. there are a few red ones around now but with different kits or wheel usually
i'll make some minor changes when it goes in for a respray :D
too bad the lambo that sported 300zx headlights was also the one with the poorest build quality (when lambo was havin a hard time makin a profit and had just been sold)... at least they painted the inside of the headlight black, which nissan didn't do for a while after.
gg. Call up some mechanics, surely there must have some sitting around doing nothing?
Will do on Monday.
Already got couple people wanting to sell me one, still waiting for reply from one with g/box about price...
Fun times ahead.
Off to work now.
same guy that owns the green 34 CR34M owns that car. was in for major works...picked up today after several long months tongue.gif
GTR-010 is currently in my driveway.
it looked IMMACULATE
i spent about 5 mins looking at it
coilpacks and loom out of the ceffy now. gonna redo the wiring and reheatshrink the lot and then wrap it in heatwrap tape.
chucked in a CA18 coilpack to replace a missing cylinder and it started firing again. so was just faulty coils. huzzah. $80 fix.
also didn't realise, but some fucker's broken a key off in the driver side door lock, and there's signs of someone having tried to force it open. lol never realised cos the alarm was keyless entry. retards must not know about ceffies, they've got the same door lock workaround as R33's. so much easier than forcing a door lock open.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
