bought swaybars for the evo, sent it to the guy that ships stuff from the US to AUS
only costed $165 shipped for front and back
only problem is the container wont leave till middle of jan next year..... itll be a late xmas present for myself :D
waddup everyone got a question
anyone good with coils, theres a set of hks hyper d coilovers for sale for $400(really negotiabe tho) , rears are said to be fine, but front passenger coil is knocking/leaking.
you rekon its fine to run coilovers in rear and standard springs in the front, then eventually get some for front, but will prob be diff brand unless i get them fixed.?
Edited by blk_sz
if you really want them grab thema dn wait till you buy fronts
however if its a budget your on buy bc/br..... do they do them for chasers?
cause they fairly cheap, have a 1 year warranty and rebuildable
only problem is the container wont leave till middle of jan next year..... itll be a late xmas present for myself :(
your wheels going to be on that boat too?
hey guys..how easy to to take the immoboliser out of the car...is it like a black box looking thing you can just disconect? let me know my daily is stuffed...thnx...any link for info how to do this will be appreciated... :(
well i am stuck and my commodore is leaving me stranded in randomly wherever i park.. :blush:
it either starts healthy or it just doesnt for an hr....waiting in a car park for an hr waiting for the immoboliser to turn off so i can start is really getting to me now...
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
