Newfagz don't know bout demon camber
In other news my wheels are getting made this week and will be here by end of Jan
So true!
What wheels you getting again?
Car was at Centerline today, drives nice and straight now :P
Funny thing is im running -4.5 degrees camber front and -2.5 rears. Fronts would be upper arms and lowness combined haha
Pics yeah :blink:
What kind of camber settings would be best for a street car that enjoys a few twisties every now and again?
-1.5 degrees all around?
I don't know much about that kinda stuff so i'm off to do some more research.
Lol demon camber looks like ass. Looks like the car is cocking it's wheel to take a piss like a dog
this... is true
matte black XD9 17x9.5+17 f and 18x10+18 r w 235/45/17 AD08's f and 235/40/18 KU36 rear
cusco upper arms will probably mean 20mm spacer up front so et will be 17x9.5-3
More tyre on the road the better. Eg billys 4.5 deg camber on front would make te car understeer like a bitch when pushed on corners
err... the point of cambering the fronts is to GET tyre on the road while turning, and hence stop understeer
see pic attached:
race cars run camber for a reason
when you turn your wheels they dont turn evenly as such, they tend to roll over and reduce the contact path, by adding camber, this roll over effect is negated and contact is again made with the road. see above how on the c-west s2k the wheel is turned and the tyre is nearly flat.
4.5 deg camber will be much much better in the twisies/track than stock setup, but will wear the tyres down unevenly for DD purposes
i'm gonna be aiming for -3 deg when i get the new rims
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
