Newfagz don't know bout demon camber
In other news my wheels are getting made this week and will be here by end of Jan
So true!
What wheels you getting again?
Car was at Centerline today, drives nice and straight now :P
Funny thing is im running -4.5 degrees camber front and -2.5 rears. Fronts would be upper arms and lowness combined haha
Pics yeah :blink:
What kind of camber settings would be best for a street car that enjoys a few twisties every now and again?
-1.5 degrees all around?
I don't know much about that kinda stuff so i'm off to do some more research.
Lol demon camber looks like ass. Looks like the car is cocking it's wheel to take a piss like a dog
this... is true
matte black XD9 17x9.5+17 f and 18x10+18 r w 235/45/17 AD08's f and 235/40/18 KU36 rear
cusco upper arms will probably mean 20mm spacer up front so et will be 17x9.5-3
More tyre on the road the better. Eg billys 4.5 deg camber on front would make te car understeer like a bitch when pushed on corners
err... the point of cambering the fronts is to GET tyre on the road while turning, and hence stop understeer
see pic attached:
race cars run camber for a reason
when you turn your wheels they dont turn evenly as such, they tend to roll over and reduce the contact path, by adding camber, this roll over effect is negated and contact is again made with the road. see above how on the c-west s2k the wheel is turned and the tyre is nearly flat.
4.5 deg camber will be much much better in the twisies/track than stock setup, but will wear the tyres down unevenly for DD purposes
i'm gonna be aiming for -3 deg when i get the new rims
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
