Love the look of the 33 Billy. Something all whale owners should aspire to. I'm in Sorrento ATM, weather is still jive hut you can feel it's gonna turn any second. Anyone know a good weather app for iPhone?
not sure if you can get it on the iphone but i use "Daily Briefing" on my samsung. does its job
I use ozweather, does the job, has rain radar and 7 day forecast etc
you going out in Sorrento tonight? my mate is playing at the Conti again
nice rear parcel shelf 6x9's billy :(
oz weather, takes the feed from the BOM, and shows BOM maps without having to navigate through BOM's archaic website.
What kind of camber settings would be best for a street car that enjoys a few twisties every now and again?
-1.5 degrees all around?
I don't know much about that kinda stuff so i'm off to do some more research.
you're better off running camber setting which will improve lifespan of tyres. In this case, you should aim for about -1.5deg on front and about -0.5 on rear. The rear you will want as neutral as possible. This will depend on height of car and the range of your camber setup.
Ive got two rear camber bush kits on the rear, best could get with my height was -1 degree
Talk to your suspension workshop regarding best setup. I recommend Traction Tyres in Rowville. They will point you in the right direction based on what you plan to use your car for.
More tyre on the road the better. Eg billys 4.5 deg camber on front would make te car understeer like a bitch when pushed on corners
The more front negative camber the better. As you turn through corners, car leans onto the outside wheel, enforcing positive camber. By dialing in negative camber, the positive camber occuring through the turn balances this out and applies more tyre to the road. Hence better grip/traction through the turn. So, if anything, less understeering.
The rear you would like minimum camber, as to provide maximum grip during acceleration (more grip to the road). However, having too little negative camber and going through a corner will create positive camber and may cause you to spin out if accelerating due to the smaller tyre footprint.
Basic explanation, so dont shoot me down with specifics
Camber = serious business
that explanation only works for RWD as well, cos AWD geometry is completely different.
Not that Kris is ever gonna get anything about camber, cos all he's interested in is going in a straight line from a traffic light :(
Thanks for all the comments ppl :(
Nankangs..?
Any good, I thought they were some pov pack tyres like NEXEN's, which I have used before...
They are alright for now, pretty grippy. Not that I care, they are rears and dont last long anyway :/
Not that Kris is ever gonna get anything about camber, cos all he's interested in is going in a straight line from a traffic light :/
haha true that. Basing my jibbajabba off my car, awd cars go speak to your suspension workshop.
hmmm If i get GTR brembo's on the front, then I wont be able to run r32 stockies on the front anymore :(
Might have to settle for some R33 GTST calipers
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
