I think the black looks pretty sick. Funky, got any more photos of black advans?
If anyone wants to chop my pic in photoshop, by all means go ahead as I am technologically retarded.
nope, rules are you have to read the whole thread before you post
hahahaha...sif...i read couple of the newer posts and post anything i have to say...cbf reading so much..even the last page...lol
This is correct
Sadly, you will be pleased to know that I just clicked through the whole lot of the pages... gee you guys can talk some shit :D
you can buy new ones maybe?
Nah, im going overseas soon so need to save mucho casho. Plus I quite like the idea of a hover-skyline.
well its true i do touch myself at night, infact im touching myself while im typing this :P
Hehehe.
Incredible, I saw you today in your yellow evo pulling out of the united servo in Wallan. Would have been around 3:30-4:00? Couldn't believe it lol.
haha really?
farking kents charging $1.50 a litre atm :(
hows it look? :P
hmm so i tried to put on an r33 gtst catback on my 34 gtt, hangers line up (just) and it sits nicely. but theres now a 15cm gap between the end flange and the front pipe flange.
problem 1 - cat wont fit in that gap
problem 2 - both flanges are on the same angle, so even if the cat fit, 1 of the flanges wont line up
solution - get a 15cm decat pipe made with both end flanges on the same angle
incase anyone was curious...
f**k im so helpful
Done,
The culprit was a bolt stuck on thorttle cable (rear of the holder bit on 26)... Here I were worrying about being carless and at least $500 out of pocket...
Damn cars, time to take up new hobby!
so it wasnt a vacuum leak afterall? :domokun:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
